IAP ARP issues
  • 1.  IAP ARP issues
    Posted Aug 31, 2016 05:20 PM
    Hi, we are running IAP-225 VC in 6 locations here on campus and we are seeing large amount of arp broadcasts from the networks where we have our IAP'd deployed, has anyone seen this or had this happen, it is causing network outage at time and we cannot determine what is the cause , our only commonality is they are Aruba IAP buildings.
    Peppino Muraca
    Sr. Network Administrator
    Stonehill College
    508-565-1193
    pmuraca@stonehill.edu
  • 2.  RE: IAP ARP issues
    Posted Aug 31, 2016 10:25 PM
    What version of Instant is this?
  • 3.  RE: IAP ARP issues
    Posted Sep 01, 2016 08:54 AM
    We are running
    6.4.2.6-4.1.3.1_55246
    Peppino Muraca
    Stonehill College
    508-565-1193
    (OO=[][]=OO)
  • 4.  RE: IAP ARP issues
    Posted Sep 01, 2016 08:56 AM
    Any idea of the source of the ARP broadcasts?  Were they gratuitous ARPs or another kind?  Did you get a packet capture?
  • 5.  RE: IAP ARP issues
    Posted Sep 01, 2016 09:20 AM
    It seems like we had some devices that were trying to use the same IP from the traces it seems all were gratuitous arps
    Peppino Muraca
    Stonehill College
    508-565-1193
    (OO=[][]=OO)
  • 6.  RE: IAP ARP issues
    Posted Sep 01, 2016 09:21 AM
    Which devices?
  • 7.  RE: IAP ARP issues
    Posted Sep 01, 2016 09:41 AM
    Please open a tac case. We don't have enough detailed information from you to determine what is wrong.
  • 8.  RE: IAP ARP issues
    Posted Sep 02, 2016 10:47 AM
    Question we are running IAP virtual controllers, if we configure option 43 and 60 on our dhcp server so the aps can find the controller, does this stop them from ARPing to find the VC ? they will still communicate using the IAP protocol correct ?
    Pino
    Peppino Muraca
    Stonehill College
    508-565-1193
    (OO=[][]=OO)
  • 9.  RE: IAP ARP issues
    Posted Sep 01, 2016 09:22 AM
    Mostly phones , iphones and androids
    Peppino Muraca
    Stonehill College
    508-565-1193
    (OO=[][]=OO)
  • 10.  RE: IAP ARP issues
    Posted Nov 30, 2020 05:52 AM
    Did you ever find a solution to this? I'm potentially seeming similar behaviour.​
  • 11.  RE: IAP ARP issues
    Posted Dec 07, 2020 01:22 AM
    i think you should enable debug pkt on the IAP, then you will find the arp issue
    command as below ( collect the logs ):
    debubg pkt type arp
    debug pkt dump
    In some versions, you can only see user's one-way arp packet because of IAP fast forward.
    hao yang
