Occasional Contributor I
IAP FW6.4.4.4-4.2.3.1_54637 Problem
After installing IAP FW6.4.4.4-4.2.3.1_54637 we have major connection issues with Chromebooks. Chromebooks cannot connect to Wifi at all.
Reverted back to 4.1.1.11 and all is fine.
Re: IAP FW6.4.4.4-4.2.3.1_54637 Problem
What model APs are you using?
What kind of SSID are you broadcasting?
Is it using encryption?
Why did you ugrade?
Model: 16x 105 and a 205
SSID: "De Sluis"
Encr: WPA2-PSK
Reason to upgrade were the mails from Aruba Product Security Advisory ARUBA-PSA-2016-004
4.1.3.0 is another good choice for 4.1.1 networks that need to beef up security.
