Regular Contributor I
IAP Firmware / 4.1.2.x , and latest 4.1.1.7
seems 4.1.2.1 was revoked from early_deployment support-download area , am i right?
ArubaInstant_Orion_6.4.2.3-4.1.2.1_49445
Build Number is "lower" than 4.1.1.7 one :
6.4.2.6-4.1.1.7_50209
perhaps someone can clearify , while the .cfg Config File is for 4.1.x i expect that i "can" downgrade from 4.1.2.1 to lower (newer) 4.1.1.7
im just trying to find out cause would like to know which InstantOS version i should advice eval customers who test Instant AP models .
thanks
ben
Re: IAP Firmware / 4.1.2.x , and latest 4.1.1.7
bg,
The build number, which is the last 5 digits is NOT directly related to versions across different code trains.  Which hardware are you looking to deploy?
no specific h/w, just collecting all the releases to provide to eval/demo customers who test the equipment while they dont have support-portal access and update button in maintenance not always showing latest version , so we provide always demo equipment with latest S/W code
therefore i ask myself what happen with 4.1.2.1 ? regarding build numbers -> 4.1.1.7 has higher build number, so this just happened by accident .
anyways. 4.1.2.1 just revoked ?
4.1.2 only relates to Cloud Wifi, so it should only be available to APs that connect to the cloud, and it should not be downloadable.
205H, 277 and 228 requires 4.2.x, so if you have a mixed cluster with those newer APs, you need to upgrade the rest of your cluster to 4.2.x, otherwise you can just stick with 4.1.1.7
