Contributor II
IAP Firmware
Hi everyone.
Somebody can give me the firmware 6.5.1.0-4.3.1.0_57768 for IAP (205/215) please.
I need it
Thank
Guest Blogger
Re: IAP Firmware
You can download the IAP software (and all other HPE Aruba software) via https://support.arubanetworks.com.
Regards
@rene_booches | AMFX #26, ACMX #438, ACCX #725, ACDX #760, CCNP R&S, CEH | Co-owner/Solution Specialist@4IP / blog owner@booches.nl
Contributor II
Re: IAP Firmware
I know that, but i cant login in in the support portal.
Re: IAP Firmware
The latest version of early access code without a support contract that supports 205 and 215 and is here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/21998/Default.aspx
6.4.4.4-4.2.3.2
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: IAP Firmware
I have this problem. i have iap-205 and i extend my wifi network with iap207. but i cannot integrate existing system with firmware mismatch error. how to solve this problem guys?
Guest Blogger
Re: IAP Firmware
Hello TuRuu,
If your cluster is built on only IAP-205 APs, you cannot automatically add the IAP-207 to the cluster. The IAP-207 needs to have the same software version as the IAP-205 APs before you add the AP to the cluster. The IAP-207 is using a different image (Vela) compared with the IAP-205 (Taurus).
The best way is to boot the IAP-207 stand-alone. Upgrade the IAP to the same software version as the IAP-205 cluster and add it to the cluster. That should do the trick.
In the future, you can add additional IAP-207 automatically. They will get their firmware pushed from the cluster. You can also update the firmware of both IAP's via the cluster.
