IAP Limitation
Hi Airheads....
limitation of IAP has been increased for only IAP-105 or for all IAP???
Re: IAP Limitation
I believe the limitation was lifted on the IAP-105, IAP-135, and IAP-175.
Zach Jennings
Re: IAP Limitation
Ohh Thanks, but i've seen some talkies on airheads telling that IAP-93 too support?
i believe its only applicable for those IAP's which you've mentioned.... :)
Re: IAP Limitation
Aruba Instant as a whole now supports an unlimited # of APs. This includes all Instant models.
XDave
Trusted Contributor I
Re: IAP Limitation
what is your source for this? because i havent seen that confirmed by aruba.
Re: IAP Limitation
From the Instant 6.1.3.1-3.0.0.2 release notes:
Improved Network Scalability
The AP limits on IAP-104, IAP-105, IAP-134, IAP-135, and IAP-175 have been removed. IAP -92/93 continues to support 16 IAPs.
Re: IAP Limitation
What happens if there is a mixture of IAP-92/93 and other IAPs?
For Example:
1x IAP-93, 16x IAP-105
or, 16x IAP-93, 1x IAP-105
Re: IAP Limitation
If you mix IAP-9x APs into a cluster, you will limit the cluster to 16 APs (even if you have 15 IAP-135s and 1 IAP-93).
