Regular Contributor II
IAP Mesh with RAP109 and eth0 bridging
I try to make a IAP Mesh with IAP-203 and RAP109 and use the eth0 of RAP109
I have enable the eth0-bridging and set a wired profile
Work on eth1 but don't work eth0
Any idea ?
ACMP 6.4 / ACMX #107 / ACCP 6.5
Re: IAP Mesh with RAP109 and eth0 bridging
you brought them both up on the wire with the same VC first correct?
Jerrod Howard
Yes
I would open a TAC case then so they can look at the details of your setup.config, or you can post your two AP's configs here (via CLI) and someone can look at them to see if something is missing. If the extensed SSID is disabled and the eth0 bridge is setup correctly, the first thing to check is if the mesh is up. If yes but Eth0 won't bridge, then it's likely an eth0 config issue or something with the port/config on the external device.
Jerrod Howard
Yes, Mesh work on enet/eth1
i will be open a case
The mesh should work regardless of ethernet config (assuming you power the mesh point with external power supply).
Jerrod Howard
