Occasional Contributor I
IAP Multicast Issue
I have devices wire into the same POE switch that my IAP's are connected to, and there is only 1 (the default) VLAN. I can't discover wired devices through multicast using wireless clients. Wired devices can discover just fine, but the IAP isn't passing the multicast.
Network Info:
DHCP is network assigned.
Default VLAN, I also tried static 1
Under the services tab, all services are selected to be enabled (bonjour, dlna, etc)
If there's any more relevant info that I'm missing please let me know. Maybe it's just a side note, but I know that when I manage IAP's from Aruba central there's an option for multicast optimization, but I'm using the Instant UI not central.
Thank you.
MVP
Re: IAP Multicast Issue
What multicast method are you using to discover devices? You may have to mess with some of the AppRF/AirPlay stuff for i-device discovery.
Under each SSID there are fields to fiddle with broadcast and multicast operation - I'd start there:
Try turning off filtering and optimization - then tuning for performace without breaking any needed 'casting.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
I don't know how I missed this. I think I was over complicating it.
Disabling broadcast filtering solved my problem.
Thank you for your quick response.
This work to me: "Try turning off filtering and optimization - then tuning for performace without breaking any needed 'casting."
