Regular Contributor I
IAP NPS authentication problems
we have some iap103 firmware Instant_Pegasus_6.4.2.0-4.1.1.0_46028 on it.
I want to authenticate one ssid with a ms nps (server 2012r2) against our active directory.
The NPS Server shows the following error:
Reason Code: 21
Reason: An NPS extension dynamic link library (DLL) that is installed on the NPS server rejected the connection request.
what is the problem?
Re: IAP NPS authentication problems
Do you have any third party authentication agents installed on your server ?
Thank you
Victor Fabian
Lead Mobility Architect
Yes there is a SMS applications in it.
That usw the NPS too.
That might be your issue , I had a similar issue with a safenet agent
Thank you
Victor Fabian
yes, the third p. agent has blockt it...
thanks a lot.
