Hi Folks,
I'm having some wierd issues with my IAP cluster.
CASE: 16 IAP's version 6.4.2.0-4.1.2 in one cluster on same broadcast domain (natvie vlan in trunks to AP, but management vlan for the network.) Differents SSID tagged to different VLAN, on same switch (cabled clients is also in this VLAN no problems when clients is on cable.)
I have 2 SSID-Profiles and 2 laptops.
Corp laptop; HP win8.1 with intel 7260 AC nic
Corp laptop; HP win7 with intel xxxx N nic
The issue:
HP win8.1; When assoiated to "Some-WiFi" the computer is getting right IP address and low ping and good SnR, everything is good. But when I'm trying to move around in the office, the PC suddenly gets a APIPA address (169.254.x.x) but still assoitated to the SSID. - If the PC has a static IP address assigned to the NIC, and roaming, no problems.
HP win7 have no problems roaming in the building, however often low bandwith, but never APIPA IP.
Bonus: NPS server always replay audit success when clients validating with valid certificate.
Log from IAP cluster on win8.1:
PMK Cache Table
Client MAC Key OKC/11r Expiry Name Role VLAN ESSID
5c:c5:d4:53:e0:d5 0711D168BD3A... okc 7h:55m:11s host/WIN8B.somenet.dk SOME-WiFI 326 SOME-WiFI
show auth-survivability cached-info
UserName Remaining Cache-Time
host/WIN8B.somenet.dk 23h:55m:10s
Total no of cached username : 1
show log l3-mobility
Apr 15 14:25:00: Foreign Sta Info from Home Virtual Controller: mac 5c:c5:d4:53:e0:d5 rcvd from 172.18.249.35 vlan 0, 0 tid 255 oldapip 0.0.0.0 fapip 0.0.0.0 hapip 0.0.0.0 vcip 172.18.249.35 info client-not-foreign
Apr 15 14:25:00: Foreign Sta Info from Home Virtual Controller: mac 5c:c5:d4:53:e0:d5 sent to self vlan 0, 0 tid 255 oldapip 0.0.0.0 fapip 0.0.0.0 hapip 172.18.249.100 vcip 0.0.0.0 info name=WIN8B,ip=172.17.1.52,o
show log kernel
00 00 00 00
[ 6011.992208] txretry:
[ 6011.992221] 0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6011.992236] 0016: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6011.992251] 0032: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6011.992266] 0048: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6011.992272] retry_seq:
[ 6011.992285] 0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6011.992300] 0016: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6011.992315] 0032: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6011.992330] 0048: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6011.992345] 0064: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6011.992360] 0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6011.992375] 0096: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6011.992390] 0112: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 6018.121888] wl0: wlc_apps_ps_flush_prec(3468): freed 0 packets precbmp : c prec : 0
[ 6018.121901] wl0: wlc_ampdu_tx_recv_delba(12193) 5c:c5:d4:53:e0:d5 tid 1 initiator 0 reason 39
[ 6018.991738] wl0: wlc_ampdu_watchdog: cleaning up ini tid 0 due to no progress for 30 secs dest : 50:1a:c5:e6:f0:99 transit : 0
[ 6018.991757] wl0: wlc_ampdu_tx_send_delba: tid 0 initiator 1 reason 39 dest 50:1a:c5:e6:f0:99
[ 6018.991838] ba_state 219 ba_wsize 225 tx_in_transit 0 tid 78 rem_window 32
[ 6018.991848] start_seq 0x18f max_seq 0x18f tx_exp_seq 0x190 bar_ackpending_seq 0x15b
[ 6018.991856] bar_ackpending 0 free_me 0 alive 0 retry_bar 0
[ 6018.991862] retry_head 0 retry_tail 0 retry_cnt 0
[ 6018.991868] ackpending:
[ 6018.991878] 0000: 00 00 00 00 00 00 00 00
[ 6018.991882] barpending:
[ 6018.991892] 0000: 00 00 00 00 00 00 00 00
show log driver
[ 5919.986047] 0064: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5919.986062] 0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5919.986077] 0096: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5919.986092] 0112: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 5943.253703] wl0: wlc_apps_ps_flush_prec(3468): freed 0 packets precbmp : c prec : 0
[ 5943.253719] wl0: wlc_ampdu_tx_recv_delba(12193) 5c:c5:d4:53:e0:d5 tid 1 initiator 0 reason 39
[ 5956.985734] wl0: wlc_ampdu_watchdog: cleaning up ini tid 0 due to no progress for 30 secs dest : 28:5a:eb:d6:14:76 transit : 0
[ 5956.985753] wl0: wlc_ampdu_tx_send_delba: tid 0 initiator 1 reason 39 dest 28:5a:eb:d6:14:76
[ 5956.985834] ba_state 219 ba_wsize 221 tx_in_transit 0 tid 148 rem_window 32
[ 5956.985843] start_seq 0x1bf max_seq 0x1bf tx_exp_seq 0x1c0 bar_ackpending_seq 0x191
[ 5956.985851] bar_ackpending 0 free_me 0 alive 0 retry_bar 0
[ 5956.985858] retry_head 0 retry_tail 0 retry_cnt 0
[ 5956.985864] ackpending:
[ 5956.985873] 0000: 00 00 00 00 00 00 00 00
[ 5956.985878] barpending:
[ 5956.985887] 0000: 00 00 00 00 00 00 00 00
I'am on the newest driver from Intel on the wireless NIC.
When I'm on the other SSID with wpa2aes-psk, no problems have been reported.
Profile0 :
wlan ssid-profile SOME-WiFI
enable
index 0
type employee
essid SOME-WiFI
opmode wpa2-aes
max-authentication-failures 0
vlan 326
auth-server SRV-NPS01
auth-survivability
rf-band all
captive-portal disable
hide-ssid
dtim-period 1
inactivity-timeout 1000
broadcast-filter all
radius-reauth-interval 720
g-min-tx-rate 24
a-min-tx-rate 24
dmo-channel-utilization-threshold 90
local-probe-req-thresh 0
max-clients-threshold 64
okc
dot11r
Profile1:
wlan ssid-profile SomeOther-WiFi
enable
index 1
type employee
essid SomeOther-WiFi
wpa-passphrase RandomPassword
opmode wpa2-psk-aes
vlan 329
auth-server InternalServer
rf-band all
hide-ssid
dtim-period 1
broadcast-filter arp
Any ideas why my Win8.1 cant roam with 802.1x but my Win7 can?
/KP-Niklas
#AP225
