IAP SSID problem.
I have an IAP 115 which i configured for an employee network with all basic settings but it does show the SSID instant and does not broadcast the newly added SSID to the clients.
Re: IAP SSID problem.
Is the SSID hidden or disabled by any chance ?
Thank you
Victor Fabian
Lead Mobility Architect
SSID is shown in the GUI but not shown or detected by clients. However i have configured all things in the simplest possible way as shown in the documents.
Thanks for your reply.
Farooq.
Try to reset the iap, else try to connect on the console, access using the ip shown in the console.
I have reset to factory a number of times , i can login through console and through GUI (ethernet port) but can not login through wifii or can not use it as a user.
From console can you run the show networks command
Thank you
Victor Fabian
It would be best to open a TAC ticket so they can help you debug; they will likely need the ?show tech-support? output in order to figure out what is going on.
Yan
Thanks for all your replies,
The problem solved with software upgrade.
Regards.
