Frequent Contributor II
IAP VC Management
Is it possible to access the VC from a guest SSID?  I am looking to just enable this temporarly for a meeting.
Super Contributor I
Re: IAP VC Management
Yes, you can. You can put a network based firewall on the SSID to prevent anyone from accessing it.
Normal Guy
If you check the IP setting details of your Guest client (ipconfig), you can obtain its IP Default Gateway. Go trougth the web to this IP and you have access on your VC. The access to the VC is always enabled by default for Guest Network.
Massimo
[If you found my post helpful, please give kudos]
Massimo Gallina
Telecommunications engineer - ACMP2013
