Occasional Contributor I
IAP Virtual controller in same subnet
Hi
Can we choose VC IP be in the same subnet and VLAN as IAP Subnet and VLAN.
If I give my IAPs range of 192.168.1.0.
Do I have to use the VC IP from the same subnet and vlan. Or should it be different?
Re: IAP Virtual controller in same subnet
You can choose to configure VC IP in a different subnet as well, using a new configuration feature added.
However it is recommended, that you keep VC IP in the same subnet as IAP subnet.
Okay got it. Thanks
If i want to prevent guest users connecting to WeBUI of Virtual controller, Can i deny them by putting VC IP address in the wizard as a particular server.
MVP
Under Security, Inboud Firewall, you can configure the subnets that can access to management. That'd solve your issue.
However, if you have an external captive portal you can also deny it on the role.
Regards
Borja
Borja
ACMX #567 //ACCP//CWNA//CWAP
