IAP Wi-Fi Uplink , Eth port suddenly not functiong (light on) but no comm between lan to unit
Hi Guys,
Good morning,
I have a an issue,
Please look on the following diagram:
I connected an AP-103 as a client to an existing Aruba network , the wi-fi uplink working great,I also converted the AP to standalone mode , and marked the SSID not to be turned off when no uplink avilable , so far so good :) MY ISSUE:  any X time if using/moving - the client connected to the IAP ETH port (That is with ETH0 bridge) get disconnected , and it's seems that the wired interface of the AP aint working (it's happning in 3 diffrent AP'S i tested with two diffrent computers connected to the ETH0 of the AP) , i in that moment im connecting to the IAP wireless , everything is working , it's just the wired port that is on but suddenly dosent do no DHCP and even no answering to Static IP pings from client to PC , reseting the unit (IAP ) solving the issue.
What might causing that? (Spanning tree?) Why the eth0 stop acting as needed while using?
Please advise .
Me.
Re: IAP Wi-Fi Uplink , Eth port suddenly not functiong (light on) but no comm between lan to unit
What version of instant?
It's happend on two diffrent InstantOS's (One of them is: ArubaInstant_Pegasus_6.4.3.4-4.2.1.2_53307 )
Tommorw i will on site and try to continue debug (And hope to solve the issue) .
Our Issue: Every once in a while ( Usually couple of minutes)  ETH PORTS seems up but stops doing any traffic to the client pc that connected to the IAP eth port.
We deployed 3 IAP units , 1 on each cart , the IAP creating a unique SSID for each cart (Different SSID for every cart) on 5GHz 44/44+ channel and ETH0 bridging marked in order to transmit the same VLAN as the cart SSID. Each IAP also connected with Wi-Fi 2.4Ghz uplink to the site Wi-Fi network (WPA2Personal Aruba controller based environment ) – the Wi-Fi uplink is usage for management only. EACH IAP on EACH cart is converted to standalone.
