IAP Wireless Site Survey
Is it possible to confgure a standalone IAP-135 for a site survey using a battery POE pack without a uplink?  Is the only option to cart around a midspan power injector with a laptop or small switch?  What are the recommended steps to configure the IAP-135?
Aruba
Re: IAP Wireless Site Survey
You can try setting the "Can be used without uplink" setting under the SSID (3.3 and higher).
You may need to convert the IAP to a Standalone AP to make this work.    Maintenance --> Convert --> Standalone AP.   If you do this, you may also need to set the uplink to Ethernet under Settings --> Uplink --> Uplink Preference.     Set the network up before converting it.
AMFX | ACCX | ACDX | ACMX
yes you can have a iap to use it as site survey...
A while ago i did a manual on how to do this
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Site-Survey-with-IAP-Manual/td-p/57274
Cheers
Carlos
Alternetworks Corp
