I have 70 IAP's on Cisco switches throughout our network. I have configured all the switchports:
switchport trunk native vlan 470
switchport mode trunk
spanning-tree portfast
All identically configured and all work just fine. IAP's get IP in correct vlan, and clients get an IP in correct vlan based on which wi-fi network ssid they choose.
I have an new AP (IAP 214) out doors that is wired to a Cisco SMB SG300-10. Switchport 8 is configured as an access port VLAN 470 untagged. Link port 10 is configured as a trunk VLANS 470 and all the other wi-fi VLAN's (400, 401, 410, 420, 430, 471) - tagged.
The trunk port is connected to a link port on a Cisco Catalyst 2960S. It is configured as switchport mode trunk. I have also just added to the configuration to specifically allow all of the VLAN's.
The IAP-214 gets its IP in the correct VLAN. However, a client cannot connect on any of the SSID's. At least on the Guest, the device gets an IP 169.254.x.x and show's up in the Aruba Console/VC.
I've tried port 8 on the SMB as a trunk with 762 and the other vlan's tagegd but then the AP wouldn't show up in the Aruba VC Console.
I have tried various config changes and they all result in the IAP no longer being seen by the VC. Any ideas? I think maybe a small tweak somehwere might fix this.
