Contributor I
IAP and Client IP assignment: Virtual controller assigned
I have configured the SSID: TC
Client IP & VLAN assignment
I set for virtual Controller assigned.
This is a flat network. No vlans or routers in the way.
  Users on the LAN side (192.168.11.x) can not reach any devices on the Virtual assigned IP's (192.168.12.x)
Access is unrestricted on the 192.168.12.x network.
Any ideas on how to fix this?
Moderator
Re: IAP and Client IP assignment: Virtual controller assigned
What is the subnet mask for both networks?
Contributor I
Both Networks LAN and WAN are using 255.255.255.0.
Moderator
If this is a flat network, it will not work. You will need to setup a router to route traffics between the two networks or simply use one of these subnets.
Super Contributor I
Can you also put the wireless clients on the LAN subnet?
-Mike
