IAP and Guest captive portal
Having just configured a bunch of IAPs for the first time, I had a few questions around Guest users and captive portal.
  1. Is it only possible to have static guest username/password?  Can we set them to expire?
  2. What about guest provisioning role for admin users.....does this exist in IAPs?
  3. Can we set an Aruba controller to be the external captive portal page?
  4. What about creating the guest users on an Aruba controller and pointing the IAP to use it as a Radius for the Guests....can/does this work?
ACCP, ACCX #817, ACMP, ACMX #294
Re: IAP and Guest captive portal
Michael_Clarke wrote:
1.  Cannot be set to expire.
2.  Guest Provisioning does not exist
3.  You can try this, but not sure it has been tested
4.  You cannot do this.
About 1 and 2, it is planned ?
ACMP 6.4 / ACMX #107 / ACCP 6.5
I'm also interested in knowing if #2 is planned...
Thanks!
