IAP and lost configuration...
Hello
I was wondering what could cause an IAP 225 to loose it's configuration after a normal power-off! Any idea's or experiences around?
btw: the IAP had just basic configuration with one ssid secured with wpa-psk. no standalone mode. worked for 2 weeks as a single access point and was powered off...
thanks
Aruba
Re: IAP and lost configuration...
Config should be committed to flash upon saving, what code build are you running?
| Adam Kennedy, Systems Engineer - adamk@hpe.com
| Service Providers – Aruba, an HPE Company
| Twitter: @adam8021x | Airheads: akennedy
Super Contributor I
I had once in my IAP135 but was on a much older code, after the upgrade it is fine. You may want to buckup your configure and then upgrade to the latest firmware.
Normal Guy
Thanks for your contributions! Indeed the AP didn't run on the newest firmware. It's now upgraded to the newest one and we'll see if the problem is fixed...
Super Contributor I
Glad we can help.
Normal Guy
