Hi all,
I am trying to configure wifi-uplink on my IAP103 (ArubaOS: 6.4.2.3-4.1.2.1) because I want to to make it work as a repeater of a third party SSID.
I have followed this guide for the configuration:
http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-configure-an-IAP-as-a-Wifi-client-though-both-CLI-and-GUI/ta-p/180362
but in all of my many test I can connect the IAP to the third-party SSID only one time!
I try to configure "uplink enfore=wifi-sta" and also to disable "uplink enforce" and give to wifi-sta the best priority, but in both ways it doesn't work fine.
If I check the status of my uplink I see this:
9c:1c:12:cd:ee:5a# show uplink status
Uplink preemption :enable
Uplink enforce :none
Ethernet uplink bond0 :DHCP
Uplink Table
Type State Priority In Use
eth0 UP 2 Yes
Wifi-sta INIT 1 No
3G/4G INIT 3 No
Internet failover :disable
Max allowed test packet loss :10
Secs between test packets :30
VPN failover timeout (secs) :180
Internet check timeout (secs) :10
ICMP pkt sent :0
ICMP pkt lost :0
Continuous pkt lost :0
VPN down time :0
9c:1c:12:cd:ee:5a# show wifi-uplink status
configured :YES
enabled :NO
9c:1c:12:cd:ee:5a# show wifi-uplink auth
wifi uplink auth configuration:
wifi uplink auth log:
[1506]2000-01-01 00:00:55.729: Global control interface '/tmp/supp_gbl'
Why does it not work? Is it a know issue of IAP?
Massimo
