IAP auto reboot
Dear Support,
I have set up a Virtual controller with one IAP as preferred master,
once the preferred master disconnect and connect back to network,
the other IAP in the group will be auto reboot,
is it a normal action or is there some setting I am missing ?
and how can I avoid this?
Alvin
Valued Contributor II
Re: IAP auto reboot
As per the normal behavior, only IAP which is acting as a master before joining back the preferred master should reboot and come up as a slave, other IAPs those were slaves will not reboot.
Please feel free for any further query on this.
Cheers,
Venu Puduchery,
