Frequent Contributor I
IAP autojoin mode how?
so my question is...
how can I join an IAP to a cluster with no use cable...I mean using wireless
Re: IAP autojoin mode how?
You need to connect them wired at least once.
Tim Cappalli | Aruba Security
And switch off extended ssid's. After once connected by wire, place the IAP in range of at least one other IAP and you get a mesh without further configuration !!
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
hello mrzero...
so I do that! but no work...
1. first all aruba IAP connecto to the switch...then dhcp asiggned IP address to them
2. delete Instant SSID, then created another..so all the IAP are connected to the new SSID
3. disconnect IAPs excep the master from the switch, then turn on the other IAPs
but not connect, so I need to do something more?
What type of IAPs ?
And what InstantOS are you using ?
Sent from Outlook for iPhone
Thank you
Victor Fabian
Lead Mobility Architect @WEI
IAP 225
Version 6.4.2.6-4.1.1.6_50009
Mesh is supported on 802.11ac APs on InstantOS 6.4.3.1-4.2 and up
Thank you
Victor Fabian
so is there way to connect via wireless the IAPS to the IAP Master Controller for this version of Aruba?
Yes .
Once you upgrade all your IAP to the required InstantOS to form a Mesh
Thank you
Victor Fabian
Thanks Man...It was solved...
I was Upgraded the firmware and then make the mesh like charm!
