Contributor II
IAP captive portal authentication against aruba controller via VPN connection
I have configure VPN connection between Aruba controller and IAP. It works fine, but i'm looking a way for clients who are connected to IAP validate against he internal captive portal of my aruba controller.
I tried to configure it using wired access control of the aruba controller (making vlan untrasted in only port who's active in controller), but it didn't work.
Anyone have any idea about how can i do this?
Thank you in advance
Re: IAP captive portal authentication against aruba controller via VPN connection
Can you provide us the output of
" show user | in <IP of client> "
Vinod Kumaar AVM ACMX, ACDX
Principal Network Engineer
Customer Advocacy | Aruba Networks Inc.
Did something you read in the Community solve a problem for you? If so, click "Accept as Solution" in the bottom right hand corner of the post.
Contributor II
192.168.20.50  00:00:00:00:00:00  d8:c7:c8:c8:f0:5a  iNNI - guest-cp_prof  00:00:06    VPN     192.168.0.127  N/A        tunnel        Win 7
I use rol iNNI-guest-cp_prof for captive portal authentication.
I assume,  the role  iNNI - guest-cp_prof has the captive portal ACLs. Then yes it should work. IF not, i request you to reach TAC.
