Occasional Contributor I
IAP client was associated to at initial authentication
Is there a way to find which AP a client was on when it first authenticated in an Instant cluster?
Re: IAP client was associated to at initial authentication
Do you have AIrwave ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I do have AirWave.
If you have the client mac address you should be able to search in Airwave and see association history of that client under client detail
Thank you
Victor Fabian
