Contributor I
IAP guest IPSEC to controller and clearpass authentication
Hi
I have read through a few articles but havent really found anything thats a bit of a step by step. What im trying to do is setup a guest authentication at several sites where users authenticate against a clearpass in the DC. Clients are then on a network that sends all traffic across an IPSEC back to the DC. This network will then be controlled via an ACL.
I dont want to have to create a VLAN for guests at each site where i just want them to share the same subnet in the DC. As well as not having any access at the local site.
Running 6.6 clearpass and 6.4.2.6-4.1.1.12_53944 for IAP
thanks
David
Re: IAP guest IPSEC to controller and clearpass authentication
Do you have an Aruba Controller at Data Center ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor I
Sorry yes, i have a controller in the DC.
Aruba7005, V 6.4.3.8
thanks
