IAP in different Vlans with the same Virtual controlleur
  • 1.  IAP in different Vlans with the same Virtual controlleur
    Posted Dec 15, 2015 08:53 AM
    Dear,
    Can i command  IAP that belong to different VLAN with a  one unique virtual controller.
    Regards
  • 2.  RE: IAP in different Vlans with the same Virtual controlleur
    Posted Dec 15, 2015 09:01 AM
    Not possible but you could manage it through Airwave from a centralize perspective
  • 3.  RE: IAP in different Vlans with the same Virtual controlleur
    Posted Dec 15, 2015 09:06 AM
    thank you but way ?
  • 4.  RE: IAP in different Vlans with the same Virtual controlleur
    Posted Dec 15, 2015 09:48 AM
    AirWave can manage and sync the configs of multiple virtual controllers. Aruba central can do this as well.
    Sent from Nine
  • 5.  RE: IAP in different Vlans with the same Virtual controlleur
    Posted Dec 15, 2015 06:47 PM
    IAPs will look for their Master/virtual controller on the wire and in order to do this they need layer 2 connectivity.
    if an IAP doesn't detect a VC it "elects" itself as master in its own cluster.
    cheers
    graeme
