IAP virtual controller still need cert for terminated EAP-PEAP and EAP-TTLS?
I just wanted to confirm that the virtual controller still needs an uploaded certificate if it will be terminating an using EAP-PEAP and EAP-TTLS. The documentation says this; however, I was playing around with an IAP on 6.1.3.4-3.1.0.0 (to which I did NOT upload any cert) and trying to authenticate with an iphone and the iphone was prompted to accept an aruba certificate. However, I was unable to authenticate. Before trying to troubleshoot that, I figured I'd just check to see if the issue is that the virtual controller still needs a cert uploaded. Thanks in advance.
