IAP
Dear community ,
How I can setup IAP-105 on backup mode , so I' won't need a modem to provide IP add.
Sultanioo
System Engineer
Email : sultan@oxygen-me.com
Frequent Contributor II
Re: IAP
could you provide more information about the setup.
When you create an SSID you have the option to either use DHCP relay or be assigned by the iAP.
If you found my post helpful, please give kudos!
Regular Contributor I
Re: IAP
If I am right, you configure it when you create a new network. It's on the first page of the SSID parameters.
