Occasional Contributor I
IAP
Hi Team,
Please could anyone shed some light on how the configuration on devices on Airwave will be communicated to the IAP's. How does the push configuration between the Airwave and Mobility controller take place. Does it involve the help of Aruba Activate?
Mona.
Re: IAP
Mobility controllers are not involved in configuration of Instant. Communication between AirWave and Instant is done over TCP 443. Activate is used to ZTP the IAPs to point to your AirWave server.
Tim Cappalli | Aruba Security
