Occasional Contributor I
IAP103 broadcast filtering and HP Airprint
Hello everyone!
Please help, I just installed 4 x IAP103. Network is working fine, but we have a HP Printer that we use via Airprint. To enable this i know broadcast filtering has to be disabled end under more, services, airgroup settings i have to select allow all to use airprint. When i disable broadcast filtering, the network becomes instable, drops speed 70% and clients randomly disconnect. Anyone got a workaround?
Re: IAP103 broadcast filtering and HP Airprint
You should be able to enable broadcast filtering and use Airprint if it is allowed in Airgroup.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Hi Colin,
No, when only airprint is activated in airgroups the printer is not visible in the network...
Type "show airgroup blocked-queries" to see if your printer is being blocked somehow..
Uhmmm... maybe a dumb question, but where do i type this?
To see if mdns printer queries are being blocked for some reason, either from your client or the printer.
I understand, but where can i see this/search this?
You would SSH into the Virtual Controller and execute it.
I'm sorry Colin, I'm not too technical, i don't understand what to do... Can you explain?
Allright.
Click on the Airgroup Bar and see if you see the printer as a client or a server.
