IAP105 Bridge Wireless
Hi ALL,
does IAP 105 support bridge wired traffic through mesh mode?
I'm trying to configure it as described in the following note, but it doesn't work.
https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-1666
I have my Instant Cluster (2 x IAP105 running 6.2.1.0) and it works perfectly.
I enable the Eth0 bridging on  1 IAP105, I reboot it and I disconnected it from the network.
After these operations the AP reboots continuosly and it doesn't work.
Gian
Frequent Contributor I
Re: IAP105 Bridge Wireless
I've tested it with latest code at IAP105. There were some improvements I guess :) Could you upgrade to 4.0?
Many regards,
Marek
Marek Krauze, CWNE# 174, ACMX #295, ACDX #356
Something cool, helpful or interesting in my post - click the Kudos Star.
Helped to solve your problem - Click Accept as Solution
I have investigated about the issue... the problem is the mesh.
If I disconnect the IAP from the network (before enabling the bridge in the wired eth), it is not able to contact the other IAP via mesh.
Have you enabled Extended SSID? If so, please disable, otherwise MESH does not work.
HTH
