Super Contributor II
IAP105 Maximum Datarate
Hi Friends,
Hope you are doing well. I have couple of questions. we have implemented IAP 105 cluster in a building. We have black listed MAC addresses of many devices ( from security- black list window) but they are still showing in clients window, We disconnect them from client window but the connect again.
second problem on every IAP all the LED are green but my a/n users are not connecting on 'n' they are keep connecting on 'a' that is why we are having bandwidth issue because maximum datarate on which they are connecting is 54 (we have implemented 802.1X). I have tested 'legacy only' option but that is already 'disable'. I have also gone through in network window here it shows only 54 maximum data rate available for 5Ghz.  please advice how to resolve this issue.
Thank you
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
Re: IAP105 Maximum Datarate
Can you check if 'blacklisting' is enabled in the SSID network wizard? Or you could share your running config with us so we can take a look.
Make sure you are not using TKIP for that ssid.  For 'n' rates it must be Open or AES encryption.
In the client window, clicking on the x to delete the client appears to do nothing.  Maybe in the background something happens, but it certainly doesn't look like that.
ACCP, ACCX #817, ACMP, ACMX #294
Thanks..
We are running AES encryption but having same problem any other advice please ?
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
Why type of clients are you using ?
From the cli can you run this command :
iap_test# show  clients
Client List
Name IP Address MAC Address OS Network Access Point Channel Type Role Signal Speed (mbps)
10.0.0.17   00:11:22:33:44:55:    test   iap_test       161      AN    test 32(good)  58(good)
iap_test# show  radio config
Thank you
Victor Fabian
Lead Mobility Architect @WEI
I will run this command and will get back to you. Thanks for the info..
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
Please see attached
1st_Floor_A# show client
Client List
ID752   192.168.50.45   64:70:02:0f:31:20           MK_WLAN   2nd_floor_B   161      A     MK_WLAN   21(good)  6(poor)
id865   192.168.50.20   cc:b2:55:56:df:51           MK_WLAN   2nd_floor_A   11       GN    MK_WLAN   38(good)  65(good)
        192.168.50.13   a0:f3:c1:3f:e6:f9           MAK_Exec  1st_Floor_A   11       GN    MAK_Exec  43(good)  58(good)
ID730   192.168.50.88   68:a3:c4:9b:91:4e  Windows  MK_WLAN   1st_floor_B   6        GN    MK_WLAN   45(good)  65(good)
ID290   192.168.50.54   28:10:7b:4d:0e:84  Windows  MK_WLAN   2nd_floor_B   1        GN    MK_WLAN   44(good)  39(good)
id845   192.168.50.92   00:1f:3c:94:90:44           MK_WLAN   1st_Floor_A   11       G     MK_WLAN   31(good)  54(good)
ID590   192.168.50.70   cc:b2:55:56:df:52           MK_WLAN   2nd_floor_B   1        GN    MK_WLAN   41(good)  65(good)
ID709   192.168.50.63   cc:b2:55:56:de:55           MK_WLAN   2nd_floor_B   1        GN    MK_WLAN   46(good)  65(good)
ID658   192.168.50.25   cc:b2:55:56:e8:c2           MK_WLAN   Basement_B    11       GN    MK_WLAN   41(good)  65(good)
ID767   192.168.50.77   cc:b2:55:56:de:56  Win XP   MK_WLAN   1st_floor_B   6        GN    MK_WLAN   30(good)  65(good)
id807   192.168.50.78   64:70:02:0f:76:96           MK_WLAN   1st_floor_B   161      A     MK_WLAN   44(good)  6(poor)
ID782   192.168.50.29   00:1f:3c:98:49:c8           MK_WLAN   Basement_B    11       G     MK_WLAN   46(good)  54(good)
ID797   192.168.50.48   64:70:02:0f:31:24  Windows  MK_WLAN   1st_floor_B   161      A     MK_WLAN   34(good)  6(poor)
ID719   192.168.50.81   64:70:02:0f:4a:07  Win 7    MK_WLAN   2nd_floor_B   161      A     MK_WLAN   25(good)  6(poor)
id808   192.168.50.34   64:70:02:0f:7d:c8           MK_WLAN   Basement_B    157      A     MK_WLAN   34(good)  6(poor)
mtc     192.168.50.43   cc:b2:55:56:e3:8e  Win 7    MK_WLAN   1st_floor_B   6        GN    MK_WLAN   28(good)  65(good)
ID340   192.168.50.52   cc:b2:55:56:df:6d           MK_WLAN   1st_floor_B   6        GN    MK_WLAN   37(good)  65(good)
        192.168.50.32   6c:88:14:b7:26:d4           MAK_Exec  Basement_B    157      A     MAK_Exec  32(good)  6(poor)
id854   192.168.50.58   64:70:02:0f:31:27           MK_WLAN   1st_floor_B   161      A     MK_WLAN   32(good)  6(poor)
id851   192.168.50.53   64:70:02:0f:86:3c  Windows  MK_WLAN   2nd_floor_A   157      A     MK_WLAN   29(good)  6(poor)
id817   192.168.50.73   cc:b2:55:56:de:5a           MK_WLAN   2nd_floor_B   1        GN    MK_WLAN   39(good)  65(good)
id585   192.168.50.108  cc:b2:55:56:e6:2c           MK_WLAN   2nd_floor_B   1        GN    MK_WLAN   43(good)  65(good)
ID754   192.168.50.94   64:70:02:0f:76:9b           MK_WLAN   Basement_B    157      A     MK_WLAN   30(good)  6(poor)
ID781   192.168.50.49   64:70:02:0f:31:28           MK_WLAN   2nd_floor_B   161      A     MK_WLAN   28(good)  6(poor)
id831   192.168.50.95   00:1f:3c:98:39:a3           MK_WLAN   2nd_floor_A   11       G     MK_WLAN   21(good)  36(good)
ID842   192.168.50.82   64:70:02:0c:2b:29           MK_WLAN   Basement_A    161      A     MK_WLAN   28(good)  6(poor)
id813   192.168.50.84   64:70:02:0f:7d:cd           MK_WLAN   2nd_floor_A   157      A     MK_WLAN   35(good)  6(poor)
ID316   192.168.50.62   64:70:02:0f:86:3f           MK_WLAN   Basement_B    157      A     MK_WLAN   32(good)  6(poor)
ID277   192.168.50.103  74:e5:43:61:9e:06  Win 7    MK_WLAN   1st_floor_B   6        GN    MK_WLAN   28(good)  58(good)
id567   192.168.50.90   64:70:02:0f:41:57           MK_WLAN   1st_floor_B   161      A     MK_WLAN   39(good)  6(poor)
id874   192.168.50.86   20:68:9d:73:b7:4c  Win 7    MK_WLAN   1st_floor_B   6        GN    MK_WLAN   31(good)  65(good)
ID883   192.168.50.42   64:70:02:0f:86:40           MK_WLAN   2nd_floor_B   161      A     MK_WLAN   33(good)  6(poor)
ID438   192.168.50.93   00:1c:bf:a9:96:dd           MK_WLAN   Basement_B    11       G     MK_WLAN   35(good)  54(good)
id872   192.168.50.76   20:68:9d:1a:68:0b           MK_WLAN   1st_floor_B   6        GN    MK_WLAN   55(good)  65(good)
ID319   192.168.50.106  64:70:02:0f:41:58           MK_WLAN   1st_floor_B   161      A     MK_WLAN   29(good)  6(poor)
ID778   192.168.50.23   cc:b2:55:56:e7:a0           MK_WLAN   2nd_floor_B   1        GN    MK_WLAN   36(good)  52(good)
ID789   192.168.50.40   64:70:02:0f:7d:8a           MK_WLAN   1st_floor_B   161      A     MK_WLAN   33(good)  6(poor)
ID839   192.168.50.57   64:70:02:0c:2b:2b           MK_WLAN   2nd_floor_A   157      A     MK_WLAN   33(good)  6(poor)
ID301   192.168.50.55   78:e4:00:b7:04:7c           MK_WLAN   2nd_floor_B   1        GN    MK_WLAN   63(good)  65(good)
id864   192.168.50.65   2c:d0:5a:9b:23:3d  Win 7    MK_WLAN   1st_floor_B   6        GN    MK_WLAN   39(good)  65(good)
id879   192.168.50.96   cc:af:78:56:e0:85  Win 7    MK_WLAN   Basement_B    11       GN    MK_WLAN   42(good)  65(good)
ID318   192.168.50.69   cc:b2:55:56:e7:8a           MK_WLAN   Ground_A      1        GN    MK_WLAN   33(good)  52(good)
id744   192.168.50.61   64:70:02:0f:23:57           MK_WLAN   2nd_floor_B   161      A     MK_WLAN   32(good)  6(poor)
id863   192.168.50.107  64:70:02:0f:86:42           MK_WLAN   Basement_A    161      A     MK_WLAN   47(good)  6(poor)
id712   192.168.50.99   cc:af:78:56:ec:62  Windows  MK_WLAN   2nd_floor_A   11       GN    MK_WLAN   52(good)  65(good)
id796   192.168.50.97   cc:af:78:7b:c9:d8           MK_WLAN   1st_Floor_A   11       GN    MK_WLAN   62(good)  65(good)
id523   192.168.50.80   cc:b2:55:56:e7:8b           MK_WLAN   Basement_B    11       GN    MK_WLAN   34(good)  65(good)
ID285   192.168.50.74   00:24:d7:52:9f:20  Win 7    MK_WLAN   1st_floor_B   6        GN    MK_WLAN   21(good)  117(good)
id701   192.168.50.71   cc:b2:55:56:e7:a3           MK_WLAN   2nd_floor_B   1        GN    MK_WLAN   44(good)  65(good)
id703   192.168.50.44   cc:b2:55:56:e7:8c           MK_WLAN   2nd_floor_B   1        GN    MK_WLAN   36(good)  65(good)
id588   192.168.50.47   64:70:02:0c:2b:2e           MK_WLAN   2nd_floor_B   161      A     MK_WLAN   31(good)  6(poor)
mis223  192.168.50.89   64:70:02:0f:6e:a4  Win XP   MK_WLAN   1st_Floor_A   157      A     MK_WLAN   23(good)  6(poor)
ID787   192.168.50.41   64:70:02:0f:23:5a  Windows  MK_WLAN   2nd_floor_B   161      A     MK_WLAN   24(good)  6(poor)
ID768   192.168.50.50   64:70:02:0c:2b:18  Win 7    MK_WLAN   1st_floor_B   6        GN    MK_WLAN   21(good)  130(good)
ID541   192.168.50.104  cc:b2:55:56:df:4a           MK_WLAN   2nd_floor_B   1        GN    MK_WLAN   37(good)  65(good)
Id871   192.168.50.60   2c:d0:5a:73:c9:70           MK_WLAN   2nd_floor_A   11       GN    MK_WLAN   41(good)  65(good)
ID478   192.168.50.36   00:1b:77:68:59:c9  Win XP   MK_WLAN   Basement_A    6        G     MK_WLAN   38(good)  54(good)
ID706   192.168.50.38   00:1f:3c:98:37:f6           MK_WLAN   Basement_A    6        G     MK_WLAN   28(good)  48(good)
id381   192.168.50.83   64:70:02:0f:6e:a6           MK_WLAN   2nd_floor_B   161      A     MK_WLAN   41(good)  6(poor)
ID819   192.168.50.87   00:24:d7:55:9b:2c  Windows  MK_WLAN   2nd_floor_B   1        GN    MK_WLAN   25(good)  78(ok)
ID792   192.168.50.66   68:a3:c4:9b:8f:4e           MK_WLAN   Basement_A    6        GN    MK_WLAN   64(good)  65(good)
mtc     192.168.50.64   cc:b2:55:56:df:4b           MK_WLAN   2nd_floor_B   1        GN    MK_WLAN   33(good)  65(good)
ID884   192.168.50.46   64:70:02:0f:6e:a7  Win 7    MK_WLAN   2nd_floor_A   157      A     MK_WLAN   35(good)  6(poor)
id718   192.168.50.68   64:70:02:0f:76:90  Win 7    MK_WLAN   Basement_A    161      A     MK_WLAN   29(good)  6(poor)
ID330   192.168.50.27   64:70:02:0f:6e:a8           MK_WLAN   2nd_floor_A   157      A     MK_WLAN   42(good)  6(poor)
ID773   192.168.50.102  00:27:10:ee:8a:b8           MK_WLAN   1st_floor_B   6        GN    MK_WLAN   21(good)  78(ok)
id843   192.168.50.85   00:1f:3c:98:37:f9           MK_WLAN   Ground_A      1        G     MK_WLAN   32(good)  54(good)
ID477   192.168.50.35   68:a3:c4:9b:91:1d           MK_WLAN   1st_Floor_A   11       GN    MK_WLAN   43(good)  65(good)
id823   192.168.50.37   cc:b2:55:56:e7:92           MK_WLAN   Ground_A      1        GN    MK_WLAN   33(good)  58(good)
ID765   192.168.50.91   a4:17:31:b0:90:29           MK_WLAN   2nd_floor_B   1        GN    MK_WLAN   45(good)  65(good)
ID882   192.168.50.28   bc:85:56:d4:1b:7f  Win 7    MK_WLAN   2nd_floor_A   11       GN    MK_WLAN   37(good)  65(good)
ID785   192.168.50.51   64:70:02:0f:2a:1d           MK_WLAN   Basement_B    157      A     MK_WLAN   35(good)  6(poor)
Info timestamp      :238049
1st_Floor_A# sh radio config
2.4 GHz:
Legacy Mode:disable
Beacon Interval:100
802.11d/802.11h:disable
Interference Immunity Level:2
Channel Switch Announcement Count:0
MAX Distance:6450
Channel Reuse Type:disable
Channel Reuse Threshold:0
Background Spectrum Monitor:disable
5.0 GHz:
Legacy Mode:disable
Beacon Interval:100
MAX Distance:600
Standalone Spectrum Band:5ghz-upper
1st_Floor_A#
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
Any Comments please ?
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
There is not enough information there to determine what your problem is.
Please open a support case.
