IAP105 and IAP115 mixed environment
Can I add IAP115 to a IAP105 environment without any additional configuration? If not, what would be the proceedure to migrate from IAP105 to 115?
Valued Contributor I
Re: IAP105 and IAP115 mixed environment
They will work fine in a mixed cluster.
Just be sure they are all running the same version of SW before joining them in the same group. Also make sure they are all part of the same regulatory domain.  Ex: IAP-105-US and IAP-115-US.
