IAP225 Firmware update on partner site is not there!
Where is the IAP firmware update for the IAP 225? is not there! in the partner site!
Alternetworks Corp
Valued Contributor I
Re: IAP225 Firmware update on partner site is not there!
I don't see it with my employee login either.   I will let TAC know so the can get it posted.   Thank you for pointing this out.
4.0.0.2 was pulled for the AP-22x only due to a bug.  The recommendation for the AP-22x is to use 4.0.0.1 till the next release comes out.
4.0.0.3 is targeted for release, with the fix, mid to end of this week.
Thank you for the info Marcus!
Cheers
Carlos
Alternetworks Corp
