IAP225 Over-the-air Mesh
  • 1.  IAP225 Over-the-air Mesh
    Posted Jan 08, 2016 01:33 PM
    Hi all,
    Is it possible to to over-the-air mesh configuration with AP225 on code 6.4.3.4-4.2.1.0 ?
    I can do wired first join, but I would like to see if there was a way without first connecting it to the same subnet/vlan as VC.
    Thank you.
    N
  • 2.  RE: IAP225 Over-the-air Mesh
    Posted Jan 08, 2016 03:58 PM
    No, it must join wired first.
  • 3.  RE: IAP225 Over-the-air Mesh
    Posted Mar 10, 2016 11:12 AM
    Hello this is somewhat related to my questions i am trying to figure out if this IAP would be able to handle mesh over a distance of about 175ft?
  • 4.  RE: IAP225 Over-the-air Mesh
    Posted Mar 10, 2016 01:35 PM
    It's possible, depending on the conditions and setup (AP orientation, channels used, noise floor, environment, etc) and use case/application. Best case would be to test it as we don't do longer range mesh testing on indoor APs.
  • 5.  RE: IAP225 Over-the-air Mesh
    Posted Mar 10, 2016 02:09 PM
    Thank you for the advice.
  • 6.  RE: IAP225 Over-the-air Mesh
    Posted Mar 10, 2016 05:17 PM
    If it's clear line of sight, no interference, no obstructions and both ceiling mounted, throughput should be approx 30-60Mbps HT20, or approx 50-100Mbps for HT40.
  • 7.  RE: IAP225 Over-the-air Mesh
    Posted Mar 10, 2016 05:25 PM
    Ok so what you are saying is I should be able to run these as a mesh with this distance as long as I have them both ceiling mounted and a clear line of sight? I mean I am talking about 5-15Mbps at the high end.
  • 8.  RE: IAP225 Over-the-air Mesh
    Posted Mar 10, 2016 05:59 PM
    Yes
