IAP3 with Huawei E160 dongle
Hi Guys,
I'm trying to get an IAP3 working with a E160 dongle in the UK on O2 but seem to be having a problem with it.
Is there a specified firmware version that I need to use on the dongle.
I have tried entering the info from the below but when i plug in the dongle the aruba just keeps rebooting.
The Aruba is using FW 6.2.1
usb_user=O2web usb_passwd=password usb_type=option (2)
usb_dial=ATDT*99***1# usb_init=AT+CGDCONT=1,'IP',''
Frequent Contributor I
Re: IAP3 with Huawei E160 dongle
Please try to connect your modem to PC or (best option) to Linux. Then check USB Device ID. Sometimes modem vendors change ID parameters. I had the same with E173.
Marek Krauze, CWNE# 174, ACMX #295, ACDX #356
Something cool, helpful or interesting in my post - click the Kudos Star.
Helped to solve your problem - Click Accept as Solution
when i check the diagnostics for the modem it says its deffinitely an E160 Revision 11.609.10.02.432
Regular Contributor I
Hi marqs,
you have your e173 settings by hand , have also some o2 branded one now with huawei firmware , still in hybrid mode. im digging into another 3G modem parameters document too , see attached - this is suitable to the other one you posted.
