IAP335. DLNA gets disconnected after x period.
Dear all,
I have got a question and thank you for your responses.
I have a setup with the following components: Samsung TV, IAP335 and a Synology DLNA media server.
When I use the default DLNA player on the television it gets disconnected with playing a video after x seconds. After that disconnect the television has completely lost it connection to the DLNA server. After x seconds the television is again able to find the DLNA server.
With my old 3rd party AP I didn't experienced any issues and therefor I suspect the Aruba AP
I have configured Airgroup. I have checked "enable DLNA" and the airgroups "chromecast", "DIAL" and "DLNA Media".  I also have disabled "broadcast filtering" on the SSID.
Do you guys have any ideas how to get this working?
