Occasional Contributor I
IAP93 Latest firmware code
Other posts state that the 4.1.1.x code chain is the latest / last to support the IAP93 Specifically 6.4.2.6-4.1.1.11 although 6.4.2.6-4.1.1.13 is also available.
Is this the latest supported code ?
The support site does list 6.4.2.6-4.1.3.0 as supporting the IAP93 is this correct or an error?
Will the whole 4.1.x.x code chain support the IAP93?
Re: IAP93 Latest firmware code
Yes.
Thanks Colin
