Contributor I
IP Scope For IAP105
Is it possible to change the IP scope  on the IAp105's when it is used as the device to assign IPs and Vlan to clients?
Re: IP Scope For IAP105
If you mean that you want to assign the range that the DHCP of the Virtual controller Assign ip address yes you can  here:dhcp.png
Alternetworks Corp
Contributor I
Thanks for the reply.
Thats what I was looking for.
Im glad that helped you Mario
Cheers
Carlos
Alternetworks Corp
