Contributor II
IPSec between 2 Virtual Controllers IAP
I have 2 VC IAPs each VC is located in a different site, and I want to configure IPsec VPN tunnel between them. Is it feasible?
Please advise,
Thank you.
Re: IPSec between 2 Virtual Controllers IAP
You will need an Aruba Controller, to terminate those IPSec tunnels.
IAPs can not form tunnels among themselves. They can form tunnels with Aruba Controllers.
