Frequent Contributor I
Installation of IAP 93 and IAP 105
If the installation have the IAP 93 and 105 on same network, the WLAN still just use one band or dual band of the two radio (2,4GHz /5GHz)?
Re: Installation of IAP 93 and IAP 105
As far i know it the 105 will use both bands and 93 well will just use one band
The thing here is that as you using and putting in the same virtual group an IAP 93 and a IAP 105 your limit of your IAPs will be 16....
Im just telling you so you can be aware of that
Alternetworks Corp
If in my environment i putting IAP 93 and IAP 105 in same virtual group. If IAP 93 become the virtual controller and the web console can i still configure IAP 105 to use both band (2.4GHz and 5GHz).
If IAP 93 operate in 2.4GHz, will IAP 105 able to operate 2.4GHz and 5 GHz at the same time or just 2.4GHz only?
MVP
Each AP will operate within the capabilities of it's hardware - the VC will not limit hardware based on whichever AP is in charge, the 93 just won't be able to go dual-band.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Then how to disable 5 ghz in rom Mode ?
regards
N.Muthu
