Contributor II
Instant AP's not joining Instant network after firmware upgrade
I have a wireless meshed network, AP-104 on main network, linking to a building with another ap-104, this remote network is connected to the main network no probelm.  If i plug in a laptop in the remote network i get an IP from the main LAN.
The problem is that no AP's on the remote site are joining the instant network, so when i look at the virtual controller i only see the two AP's providing the mesh link.
When i boot one of the AP-93's i get the following message over and over again:
Rebooting AP due to uplink ap denied me, from (MAC and IP of remote LAN Meshing AP)
I have just gone to the latest firmware 6.3.1.1-4.0.0.1_41049, this seemed to have caused the problem.
Any info / ideas appreciated,
Dave
Contributor II
Re: Instant AP's not joining Instant network after firmware upgrade
This is not a new install and was working fine on the old firmware!
Dave
Do you have auto join enabled ?
Is it possible for you to check if the mesh point (console boot process) was able to go through the upgrade ?
Thank you
Victor Fabian
Lead Mobility Architect
Contributor II
Turns out its a version 4 firmware issue.
We had just a basic layer 2 bridge, so the main lan (building a) was extended to the remote site (building b), in building b we have more AP's for extending wireless coverage in building b.
Version 4 stops this working!!
knightmare day!
Have you tried 4.0.0.2 ?
Thank you
Victor Fabian
Could you also share with us the version number that you were using before which was working?
Contributor II
I had a called raised with TAC, they didnt suggest to go to 4.0.0.2 at the time, and i needed to get it back up again so decided to roll back.
I had to roll backto 6.2.1.0-3.4.0.5 for it to work.
The latest available firmware on autoupdate will break the network described earlier.  Apparently the two mesh AP's will need to be in a dedicated instant network, This instant network when denies any other AP's in building b to join the instant network.  These AP's would need to be in their own instant network.
Dave
