- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Instant Features
Instant Features
09-08-2014 12:18 AM
I have been given an IAP103 for evaluation and there are a couple of features I can't find:
- How did I configure the supported and mandatory data rates? I can find the minimum and maximum legacy data rates but not where to configure the mandatory data rates.
- Without using an external captive portal can I resize or reconfigure the captive portal so it displays better on tablets and smartphones? The default internal captive portal is too wide for tablet and, particularly, smartphone displays.
One feature change I would like to see is the ability to change the SSID's default role so that it is not alreadys the same as the SSID. This is a "nice to have" rather than a "must have".
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Instant Features
09-08-2014 05:16 AM
1. The min and max rates (transmit and basic) are found in the advanced link when you add or edit a network. That link is found in the lower left.
2. This is not supported. You would need an external captive portal like Clearpass to display a mobile page.
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
09-08-2014 12:29 PM
Thanks for the reply Seth.
I found the minimum and maximum transmit rates but I am looking for where I configure the mandatory and supported data rates. For example, I may want to configure the data rates as follows:
* Not Supported - 1, 2, 5.5, 6, 9, 11 Mbps
* Mandatory (Basic) - 18 and 36 Mbps
* Supported - 12, 24, 48, 54 Mbps
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
09-14-2014 02:01 AM
I have been looking at a cost effective external captive portal solution and the ones I have found are all Linux based, which will mean that we need to build a Linux VM. Is anybody aware of an easy Windows based external captive portal solution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
