MVP
Instant OS DHCP Issue
Hi ,
i configure my IAP 275 (Firmware 6.4.2.3-4.1.1.2) , with local L2 DHCP.
i found two surprise
  1. each time i configure the DHCP , the configuration disapear, but when i access with the command line i found the dhcp configuration , worse i can't remove it.
  2. the L2 DHCP configuration was removed from the configuration Guide
I think that's a bug , have any one  met the same problem
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
