Instant TACACS+ management roles possible?
Dear all,
I try to configure the TACACS+ authentication for Instant controllers.
Basically it works, but is there a way how I can use different access roles for the users?
I need normally an admin role and something like a "monitor" for read only.
Is that possible? Or if it is not with TACACS+, is it possible with RADIUS?
Thanks a lot!
Sven
Regular Contributor II
Re: Instant TACACS+ management roles possible?
Are you using clearpass as a tacacs server ?
Valued Contributor II
Cheers,
Venu Puduchery,
Hi friend,
It is absolutely possible :)
Please feel free for any further help on this.
Cheers,
Venu Puduchery,
No, we are using the Cisco ACS 4.x and in future 5.x.
Can you describe how I have to configure that? Is there something I have to add in the instant controller or on the TACACS+ server?
Trusted Contributor I
this seems to indicate it is not possible to assign different roles
http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-to-authenticate-IAP-admin-user-against-CPPM-over-TACACS/ta-p/192931
you might experiment with level 0 or 1 and see what that does.
Thank you very much for the link.
So it seems that this is not working.
Is it possible to assign different roles with RADIUS?
Management roles for TACACS+ and RADIUS will be added in Instant 4.2 which will be released in the coming weeks.
Tim Cappalli | Aruba Security
