Activate is working, that is correct.
I'm not using a whitelist. Shared Secret is set. Authorize Aruba IAPs connecting to Airwave is set to All.
1st VC is accepted, IGC config is set. Second IAP is added manually (by the customer) because it wasn't known in Activate and the Cloud Activation Key didn't appear.
I have been trying to similate the above with my own setup. I have no access to Activate so I used DHCP option 43 and 60 to automate the provisioning. For me it's working as expected; the 2nd and 3th VC's are added automatically. I assume that using DHCP will be te same as using Activate. Pass on the group, Airwave IP and shared secret.
Even adding an IAP manually to Airwave is working without me doing anything in AIrwave.
I will go back to the customer informing him that a mistake must have been made somewhere in the setup or the thinking progress and that the process is working as has been sold.
I will get back to this when I receive a reply.
thanks
Erik
