Occasional Contributor I
Instant and VLANS
Hi.
We have setup AP's in one VLAN and the extra APS showed up and configured.
How can we have the other AP's configured automatically on same switches but differentVLAN?
Thank you
Re: Instant and VLANS
They are designed to be in the same management VLAN.  If you are forced to have a different VLAN, you should create a separate cluster.
