pok
Instant firmware upgrade issue
My IAP 305s are running with firmware 6.5.1.0-4.3.1.0_57768. The latest version available is 6.5.2.0. I tried to upgrade the firmware manually but got the error "Invalid Image File".
Then I tried "Automatic" and it said there is "-- No new version available --".
Next I tried the debug-download command and was able to successfully connected to the image server but the images are not available(I tried two version).
The firmware filename is ArubaInstant_Vela_6.5.2.0_59123
Re: Instant firmware upgrade issue
For the 305 it should be Ursa.
Please see the limited lifetime warranty upgrade page here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/25165/Default.aspx
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
pok
Thanks. Do you know why my support page only have Vela?
Another question: are the MIB file the same? or there is a Ursa version of MIB?
Mib files are the same across all models.
What is the URL of your support page?
pok
HPE Support -> My Networking Portal
I clicked one of my registered 305 AIP and it took me to the firmware page contains only Velsa firmware...
If you could paste in the URL, and a screenshot, that would be good.  Meanwhile, please use the URL that I posted above...
