Instant managment access, when WAN connection is lost to Aruba Central
  • 1.  Instant managment access, when WAN connection is lost to Aruba Central
    Posted Nov 25, 2016 05:24 AM
    Is it somebody that knows if it's possible to gain management access to a Aruba Instant cluster locally if the Instant Cluster drops wan connection or loses connection to Aruba Central?
  • 2.  RE: Instant managment access, when WAN connection is lost to Aruba Central
    Posted Nov 25, 2016 06:47 AM
    If your cluster loses access to Central it will allow you to configure the cluster locally.  Please see here:  https://www.youtube.com/playlist?list=PL37Y-XxK6oanTV3821XpKHFVo3hGPW-56 for more videos on Central and Instant.
  • 3.  RE: Instant managment access, when WAN connection is lost to Aruba Central
    Posted Nov 25, 2016 07:23 AM
    Just to clarify, what i mean with "lose" connection!
    The local network should still be available without a WAN connection and that you can manage the Instant cluster.
    I know i can manage the Instant cluster if i remove the licenses from Aruba central, but i have not seen that it is possiable to manage the Instant if the WAN connection drops or when the connection to central is lost.
    Are you really sure of this?
  • 4.  RE: Instant managment access, when WAN connection is lost to Aruba Central
    Posted Nov 25, 2016 07:38 AM
    Aruba Instant configuration takes over if the connection between the instant cluster and central is interrupted.  Yes.
