Contributor I
Instant mode with 2 level of backup
Hi!
I've got question. In attachment there is topology of 2 level backup. Is there any possibility to configure Aruba Instant like that?
Thanks in advance!
Re: Instant mode with 2 level of backup
The only issue there is that the RAP3 won't be able to do a mesh connection since those only support 2.4Ghz and the mesh link is built using the 5Ghz band .
You can potentially try having an IAP105(Virtual Controller)  configured the wired profile as an uplink and connect it to one of ports of the RAP3  and that IAP105 will make the mesh connection back to the other IAP105.
Hope it make sense
Thank you
Victor Fabian
Lead Mobility Architect
Contributor I
Thank you so much!
