MVP
InstantAP Nexus 4 won't connect to SAID with WPA2 Personal (Android 4.3)
[ Edited ]
Hi Guys,
I encountered some issue,in one of my clients site.
(SMB OFFICE) with more than 30 units of Nexus 4
  • Android 4.3 on Nexus 4 phone , just wont connect to any WPA2 Personal ssid that being created with InstantAP105 - Dosent matter with AOS (even the newest) :smileysurprised: **cant see the MAC of the client(S)  on any show log / Gui interface**
  • Android 4.2.2 on Nexus 4 phone , Connecting as needed to WPA2.  :smileyhappy:
even due it's seems an issue belong to google team and  Nexus 4 + 4.3 (Because other vendors - android smartphones with diffrent android os 4.1 4.2.2 4.3 4.3.1 4.4 /pc/apple devices  connecting as needed to WPA2 and working well)
I still wanna share with the config:
This is the config example - (this config is after  I changed it to WPA1 Personal - BTW  with WPA1 everything work like charm!) :smileyhappy:
version 6.2.1.0-3.4.0
virtual-controller-country IL
virtual-controller-key bc76a0c101b0c8ad371d4e09ec6b0aad0dc58cdcece5343e4d
name Instant-CB:8C:BE
terminal-access
ntp-server 192.114.62.250
clock timezone none 00 00
rf-band all
allow-new-aps
allowed-ap 6c:f3:7f:cb:8c:be
allowed-ap 6c:f3:7f:cb:8c:bf
allowed-ap 6c:f3:7f:cb:8c:d9
allowed-ap 24:de:c6:c3:eb:02
allowed-ap 24:de:c6:c3:ea:9a
allowed-ap 24:de:c6:c3:ea:ee
allowed-ap 24:de:c6:c3:d2:fa
arm
 wide-bands 5ghz
 min-tx-power 12
 max-tx-power 18
 band-steering-mode prefer-5ghz
 air-time-fairness-mode fair-access
 client-aware
 scanning
rf dot11g-radio-profile
 dot11h
 interference-immunity 3
syslog-level warn ap-debug
syslog-level warn network
syslog-level warn security
syslog-level warn system
syslog-level warn user
syslog-level warn user-debug
syslog-level warn wireless
mgmt-user admin 453e1d68f86d9a43120c46295a3e11db
wlan access-rule default_wired_port_profile
 index 0
 rule any any match any any any permit
wlan access-rule everything
 index 1
wlan access-rule everything-guests
 index 2
wlan access-rule default_dev_rule
 index 3
wlan access-rule cable
 index 4
wlan access-rule tunnels
 index 5
wlan access-rule wired-instant
 index 6
 rule 10.0.254.10 255.255.255.255 match tcp 80 80 permit
 rule 10.0.254.10 255.255.255.255 match tcp 4343 4343 permit
 rule any any match udp 67 68 permit
 rule any any match udp 53 53 permit
wlan access-rule everything-dev
 index 7
wlan access-rule everything-users
 index 8
wlan ssid-profile everything
 enable
 index 0
 type employee
 essid everything
 wpa-passphrase be166a11f2e8c0e6127d7ed0b942ec7a2a95d7701edcbc8d
 opmode wpa-psk-tkip,wpa-psk-aes
 max-authentication-failures 0
 vlan 2
 auth-server InternalServer
 rf-band all
 captive-portal disable
 dtim-period 1
 inactivity-timeout 1000
 broadcast-filter none
 blacklist
 dmo-channel-utilization-threshold 90
 local-probe-req-thresh 0
 max-clients-threshold 64
wlan ssid-profile everything-guests
 enable
 index 1
 type employee
 essid everything-guests
 wpa-passphrase 59216016e4d8e027c3cbd0a40eef943fc792c754ff0e466e
 opmode wpa2-psk-aes
 vlan 2
 rf-band all
 dtim-period 1
 per-user-bandwidth-limit 1000
 blacklist
wlan ssid-profile cable
 enable
 index 2
 type employee
 essid cable
 wpa-passphrase 7aef79580fca6d5df5a8b2b184ec12f01b881fca1d3d5dbb
 opmode wpa2-psk-aes
 vlan 10
 rf-band all
 dtim-period 1
wlan ssid-profile tunnels
 enable
 index 3
 type employee
 essid tunnels
 wpa-passphrase b9b2998dd428332ff121e033683eaf995c95cfbc9a1be321
 opmode wpa2-psk-aes
 vlan 22
 rf-band all
 dtim-period 1
wlan ssid-profile everything-dev
 enable
 index 4
 type employee
 essid everything-dev
 wpa-passphrase 35c2c6046d0a28d332f04c23556da45861f0234e46f3bc1e
 opmode wpa2-psk-aes
 vlan 3
 rf-band all
 dtim-period 1
wlan ssid-profile everything-users
 enable
 index 5
 type employee
 essid everything-users
 wpa-passphrase 0f04838e192937c1853e7757beee503107af8cc8614c5143
 opmode wpa2-psk-aes
 rf-band all
 dtim-period 1
auth-survivability cache-time-out 24
wlan external-captive-portal
 server localhost
 port 80
 url "/"
 auth-text "Authenticated"
blacklist-time 3600
auth-failure-blacklist-time 3600
ids classification
ids
 wireless-containment none
wired-port-profile default_wired_port_profile
 switchport-mode trunk
 allowed-vlan all
 native-vlan 1
 shutdown
 access-rule-name default_wired_port_profile
 speed auto
 duplex full
 no poe
 type employee
 no dot1x
wired-port-profile wired-instant
 switchport-mode access
 allowed-vlan all
 native-vlan guest
 no shutdown
 access-rule-name wired-instant
 speed auto
 duplex auto
 no poe
 type guest
 no dot1x
enet0-port-profile default_wired_port_profile
uplink
 preemption
 enforce none
 failover-internet-pkt-lost-cnt 10
 failover-internet-pkt-send-freq 30
 failover-vpn-timeout 180
airgroup
 disable
airgroupservice airplay
 disable
 description AirPlay
airgroupservice airprint
 disable
 description AirPrint
:robotsad::robotsad::robotsad::robotsad:
  • If anyone encounter issue similer like this and solve them - please share some tips.
  • if anyone encounter Wi-Fi issues with nexus 4 (With 4.3) please share ...
Me
